Anonymous
Mar 04, 2014Sprinter Tires
After 40,000 hard miles on the original Continental tires, I figured it was time. Six new Michelin LTX M/S 2. So far just driving west from Albuquerque I can tell the ride is quieter and smoother. Steering is as good or better, no surprises. The old tires were not "Worn Out", but it was time. The tire shop had all the wheels off when they discovered the steel valves would not fit Sprinter wheels. The best they could do is brass ones that are shorter than the originals that made airing up the tires hard enough. So, when I get home I will need to get new valves or maybe extenders. One advantage the new valves have over the old ones is that they don't squirm and squiggle when you try to get an air chuck on it, that is if you can get to it. Also, I have 64 PSI all the way around and seem to be just right. Any recommendations on tire valves and air pressure for the Michelins?
