RLS7201 wrote:
John&Joey wrote:
Pumping up normally means you have a bad gasket somewhere in the brake system. But, with that said....
The older 460 F53 was know to generate a lot of heat and boil the brake fluid. Fresh fluid is a yearly must, plus look for the highest quality/boiling point that will work in your system without damage to it.
I would really like to know where that gasket might be, so I can make sure mine is not leaking.
Richard
That would be in the master cylinder or the brake calipers. I figured an old guy like you would have rebuilt those in years gone by. OK they would be called seals, work with me on this would ya, and stop being such a PIA.
