kimberlysmoore
Mar 31, 2018Explorer
Whining brake pedal
When I turned the ignition to on and put my foot on the brake pedal yesterday it was whining like a little motor was running. We drove around for a few miles.  I noticed the brakes got spongier but not consistently.
I pulled the cap off the 3 month old master cylinder and noticed the rubber bulbs popped out. I pushed them back in and added some brake fluid and searched for a leak we must have. There’s a small one at one of the junctions of the new lines they replaced 3 months ago. Put the lid back on and drove an hour no problems, no noise.
Parked overnight and now the noise is back this morning.
Pulled the cap off again and noticed the rubber inside that has the bulbs on it is super loose and one bulb was partially popped out again.
Now the noise happens when I press the brake pedal even when the key is off.
1990 Bounder 40z Ford fuel injection v8 Oshkosh chassis
❚ Did you see the "Announcement : ★★READ BEFORE POSTING HERE★★"?
- Forum Posting Help and Support is reserved for questions related to posting issues with Open Roads Forum sites, member profile and photo testing, and for reporting account issues. Please avoid using this forum for RV related questions, as doing so can delay responses to your thread.  Instead, select the Sub-Forum which corresponds to the subject of your topic.  Thank-you!
Moved from FORUM TECHNICAL SUPPORT
