Ksrow's avatar
Ksrow
SRS Airbag light on Thor Mercedes Sprinter Siesta
:cheers: Had an SRS Airbag warning light come on only two days after I took delivery of the coach, a 2014 Thor Four Winds Siesta Sprinter Chassis. Checked under the seat after seeing a thread on another RV forum about how swiveling to face the rear on the drivers side causes the seat belt wire connector to detach. Sure enough a yellow connector was disconnected from swiveling the seat to face the back. When you reconnect you need to spend some time moving the seat fully back and forward as well as full swivel in all directions. The cable must be routed just right or it will just pull apart again the next time you swivel to face the rear. I was lucky in that even though it cracked the connector it didn't pull the wires apart (they are very small gauge). I also wrapped the connector with electrical tape to protect it better. This great thread saved me 30 mile round trip to freightliner. Poor routing from the factory. :h
No RepliesBe the first to reply
