lryrob9301
May 05, 2014Explorer
alkillion wrote:
Did I see you mention your rig was a diesel? If that is the case, you may need to look into other additives. There are many on the market, personally I use Biobor products for diesel. I do use Stabil for my cars (gas).
In a diesel fueled vehicle Biobor is the only additive needed. Diesel fuel does not deteriorate like gasoline when in storage. It does develop microbe growth which can clog fuel filters, pumps, and injectors. Neither Stabil nor Seafoam effectively combat this microbe growth.
As mentioned above run the generator monthly but the motorhome engine should not be started unless it and the transmission can be brought up to full operating temperature.
38,782 PostsLatest Activity: Sep 02, 2026
