Gjac's avatar
Gjac
Explorer III
Aug 07, 2019
Stabilizing a Class C
I notice that many Class C's do not have automatic levelers and many just use blocks under the tires. My question is with the MH just being supported by the suspension how do you keep the MH from moving when you walk inside? Is the movement less in a shorter class C say 24 ft vs 30 ft? Is the movement less with a heavier suspension say 450 vs 350? Been looking at 24 ft MH's with a full wall slide. In my Class A I notice a lot of movement when the levelers are not extended.
  • I have a 24' 2012 Nexus E-350 C, no slides or levelers, I use the yellow Leggo blocks and they work just fine. Hardly any movement in the coach. The heavy duty Bilstein's probably help.
    :C
