j-d
Nov 23, 2015Explorer II
Using the "Prime" function for gasoline-fueled ONAN genny's (as Phil noted) is a very good idea, and something many of us didn't know was available till recently. I prime ours till I hear the pump stop its tapping sound. Then I attempt a start. It sometimes actually does start. If not, I repeat the priming and listening, the do a second attempt. It always starts then.
OP - Fully closing the choke is a good idea and I've done it in the past. I do NOT think the Microlite will cause this possible hazard, but... Be sure it's the Choke and not the Throttle. The older ONAN's would go right to 160-volts-plus if you tweaked the throttle. The one that did that with me had no electronics, just a mechanical governor. I think Microlite won't allow that much voltage. I'm just not sure and I just don't feel lucky.
38,782 PostsLatest Activity: Aug 31, 2026
