I have a 2000 Southwind on the F53 platform with a V10, when I tried to start it today the engine turned over but would not stay idling, I tried a couple times and it did the samething. This happened ...
My 1999 32v v-10 used to the same thing,I made sure i changed the fuel filter every 5000 miles, cause you never know what kind of gas you can pick up on the road.Plus the air cleaner, if it gets wet it can cause the motor to stall,or rough idle.I always use STABLE in the gas at different times when ai fill up.
