tenbear
Oct 22, 2014Explorer
What converter does your Class C have? If it is a Magnetek or Parallax be sure to check the water level in the coach battery every 2 weeks until you find out how often it needs water. These old converters are single stage and the voltage that it runs at is a compromise between charging and maintenance. If it has a modern converter, such as a Progressive Dynamics 9200 or 4600 series, you won't have to add water as often but you should still check the water as above to see how often it needs water. It probably won't need much water.
38,782 PostsLatest Activity: Sep 10, 2026
