MinWin
Feb 12, 2015Explorer
Staying Warm
Just bought our first motorhome: 1998 Winnie Winnie 31'. Can we travel in this vehicle in winter and stay warm?
pnichols wrote:
Of the two types of electric heaters we tried - the radiant heat type was far superior in making us feel comfortable immediately and continuously. The radiant heater was physically much larger, but if we were to do serious cold weather camping and mix some electric heat in with propane furance heat ... I'd definitely want the electric heat watts to be of the radiant type.
It seemed to us like we were getting way more comfort per watt with the radiant heater.
Pianotuna wrote:
My propane runs out in 72 hours in -30 weather. Tank is 60 pounds.
pnichols wrote:
your comments started me thinking. You say that only the propane furnace supplies the neccessary BTUs to keep the coach area warm so therefore the generator by itself powering electric heaters is not an option. This situation doesn't mean that you can only keep warm until the propane runs out using only the propane. I'll bet your propane furnace could be used more days when drycamping if you ran it at the same time as the generator and electric heaters and thus keeping the propance furnace's ON cycles much shorter. Using these two together in combination may extend your cold weather drycamping time way beyond what you could get by using only the furnace by itself with the generator/electric heaters not being used.
turbojimmy wrote:
I would measure the cold camping days in propane. When it's below freezing, electric heaters don't touch the cold in a "standard" rig (not permanently parked and insulated). While my generator is 6,500 watts only 30 amps of it (27.4 to be exact) is available for heaters, split between 2 circuits. The 1500 watt box-store heaters don't come close to cutting it. My front furnace is 35,000 BTUs and the rear is 18,000 BTUs. Based on recent experience, I can probably get between 5-6 days of heat with ambient temps around freezing (32 degrees F) out of my 80 lb. propane tank.
pnichols wrote:
Just out of curiosity ... I wonder how many days some of you have gone, or heard of others going, drycamping in the extreme cold in a non-expedition-type (i.e. "regular") Class C?
For starters .... I guess that with our Class C that would be the number of continuous days until the propane ran out and then add to that the number of continuous days that the built-in generator could be run off the main engine tank and still leave us enough fuel to get out to a gas station. That's assuming we start out with a nearly full main fuel tank and that a 4000 watt generator can supply enough BTUs to keep the RV warm 24/7. We don't have solar, so that's not a consideration ... but probably solar is of only marginal use in the extreme cold anyway - as it is in the extreme heat.
I always find extreme heat or extreme cold dry-camping discussions more interesting because self-containment capability, when needed, is why some folks spend the $$$ for a Class C in the first place - at least for camping in the Western U.S. with it's extensive dry camping opportunities. Many extreme camping situations are easily dealt with when on FHU ... but when dry camping in the cold things can get really challenging (and interesting).
