Matt_Colie
Feb 08, 2017Explorer II
Bob,
If those are truly steel formed lines and they are "soft" you have big problems with the cooling system. The coach must have been run with the coolant corrosion inhibiters depleted.
Steel cooling lines are usually used when the span is too great for a rubber hose to be self supporting. If you can span the distance, or arrange support you can use rubber.
Matt - the OE refugee.
38,782 PostsLatest Activity: Sep 10, 2026
