joe0508
Apr 28, 2013Explorer
steer safe
I finally got everything put together with my steer safe stabilizer.There not enogh tension on the srings and i was thinking maybe i couldget some loger eye bolts to get the tension that will give me ...
rgatijnet1 wrote:joe0508 wrote:
It seems to me that with longer eye bolts i can slide the fulcrum further back than i will have the extra threads to pull the springs back further.Am i wrong with this theory?
I theory that is correct but what if you over-extend the springs? Those springs were designed at that length for a reason. You may be able to stretch them further, but you have to wonder why they didn't do that at the factory. You also have to think about the eye bolts that you want to use. Are they the cheap Chinese eye bolts found at Home Depot, or are they the hardened steel eye bolts supplied by the factory?
If you stretch the springs past the point of no return, they would be weaker, and it could make the whole unit useless.
Thousands of people have used SteerSafe as designed. Take a good look at the installation instructions and figure out what you are doing wrong.
