JimExplorerApr 14, 2016Steer tire width...Thinking of changing the steer tire width from 9.25" to 11" with all the other specs the same or better. Object is to save money and get a tire with extra long tread life. Any expert opinions on ch...Show More
Mr_Mark1ExplorerMay 05, 2016Jim, you are only talking 500 lbs.... in the whole scheme of things, I wouldn't worry about it. If it's easy to adjust a few things, fine. But, don't drive yourself crazy over that minor weight difference. Did you have a passenger with you? If not, that will adjust it a little.MM.
