mrcchiefe7
Jul 09, 2013Explorer
I have talked to both Thor and Ford about the handling problem tracking and steering wheel not returning to center after making a turn (R/L). Ford is saying that we are 400#'s to light on the front axle and this is causing the problems that we are having. Ford also stated that air bags or new springs are required in the rear to raise the rear to add the additional weight to the front axle. The rep at Thor is to talk to his tech to see what can be done. Here are the actual weights that we have Front 4340#, Rear 9200#, Gross 13540#. Weight spec are Front GAWR 5000#, Rear GAWR 9600# and GVWR 14500#. Ford also stated the the problem is with Thor.
38,769 PostsLatest Activity: Apr 04, 2026
