j-d
Jul 09, 2013Explorer II
You've said "won't return to center" and also "handling problem." How does it track once you get the wheel to center? If you can comfortably stay in your lane and aren't overly affected by wind gusts and passing vehicles (there will be SOME effect, much more than in a car or even SUV), then I'd say get something like a Safe-T-Plus. That was mentioned above.
The spec I see quoted as being Ford's requirement for front axle loading is 32% of total scale weight. Right where you are. I don't think they can expect you to max the front axle load.
Somebody explain to me how raising the chassis say 2" at the rear is going to transfer more than a few pounds to the front axle. I hear that from time to time and don't understand how it would work.
Is that 1/8" of Toe "Toe-In" or "Toe-Out?"
What's the total length of your coach, and what is the Wheelbase?
38,769 PostsLatest Activity: Apr 04, 2026
