retiredhfd's avatar
retiredhfd
Steering wheel squeals when I make hard turn ???
My steering wheel on my 2003 Fleetwood Excursion 38' makes a loud squealing noise near the base where it goes through the floorboard. It only makes the noise on hard turns. Any suggestions ?? By the way whoever suggest checking my rear camera connection at the rear of the coach(lost Picture) was right on target. The connection just came lose. Thank you so much. It was a job because I had no rear inspection plate. I had to remove the camera mounting plate by removing 4 pop rivots. I had no idea they make a 5/16 pop rivot. Found the 5/16 rivot but haven't found a rivot gun that big yet - what a pain. I have temporarily t fixed but not right yet. Still looking for that big gun. I'm going to check a tool rental place tommorrow. LOVE THIS FORUM.
  • I'm assuming that the Excursion is a gas model? If so, there is two possibilities, both an easy fix.
    1. The power steering belt is loose, just tighten it up.
    2. The power steering belt is worn out, the mating surface is very shinny and not able to grip the power steering - replace the belt.
  • Check the powersteering fluid level and also the belt condition adjustment etc. some where to start
