wjschill's avatar
wjschill
Steering wheel vibration
I saw a video of a test drive on a 2015 F/W Bounder, and noticed the steering wheel had quite a bit of vibration traveling down a smooth highway.
I have also heard that this is normal on the F53 frames for the class A gassers. Some even say that this vibration contributes to driver fatigue after about 4 to 5 hours on the road.
So, my question is...Is this normal for the F53's and is it really an issue?
We are still looking for a (used) class A, but for a few trips each year, I really can't justify the extra $$$'s for a diesel pusher. Not to mention, most are forty feet long, and not a great fit for state park camping.
Thanks....Skip
  • rgatijnet1 wrote:
    There are many things that can cause a steering wheel vibration. I doubt that it is common with ALL F53 chassis RV's. Wheel out of round, wheel out of balance, loose wheel bearing, bad shock, loose/worn suspension components, alignment, loose steering box, etc.
    +1. we’re on our second F53. no steering whl vibration on either.
  • There are many things that can cause a steering wheel vibration. I doubt that it is common with ALL F53 chassis RV's. Wheel out of round, wheel out of balance, loose wheel bearing, bad shock, loose/worn suspension components, alignment, loose steering box, etc.
