Tom_Barb
Apr 11, 2016Explorer II
Moffittclan wrote:there should be a decal on the battery that tells you when they went in service. But if they are not able to charge 1, the other is not far behind. I'd do new quality batteries now. while you are at it, clean all connections including the Neg ground on the frame.Tom/Barb wrote:
First of all, how old are your chassis batteries? next did you check them prior removal? What voltage were they? Did you try to charge them with a external battery charger? How long was the interval between usage? When was the last time the connections were cleaned?
I just bought the coach a month ago so I don't know how old the batteries are but they certainly look like it's time to change them out. I put a meter on them yesterday (while still installed and connected in parallel) and they both read about 7v. Took them out this morning and they read 11.3v. Dropped them off at Autozone and he was reading 9volts...
Just got off of the phone with Autozone. One charged fully but tested bad with a load on it and the other wouldn't fully charge so they couldn't test it. So that looks like one issue at atleast!
