klutchdust
Jul 15, 2020Explorer II
wtravlr1 wrote:
If they are Kwikee steps, most likely the nylon gear is stripped. Need a new motor assembly. Easy install. Or if you are really mechanical you can take it apart and rotate nylon gear 180d. and it will work for a while longer. Just make sure to unplug all electric to steps while working on them. kwikee motor change
yup, did exactly that and it works fine. Gears are metal. Lubed well and re installed.
