Hal the Van is at the shop tonight getting some welding work done on a couple of places that need more than what I can do with Bondo.
Anyway I have a new question. I'm drawing up my van layout and am leaving the right rear corner (passenger side) of the van free for a possible toilet. I'm not sure if I'll add one but want to leave enough space for a future installation. This would be free standing, not an enclosure. Also not sure of what type I'd go with (Porta, blackwater).
What is the minimum space (width) I should leave free?
Thanks.
On a separate note, here is the wiring scheme:
Since must of my camping is boondocking I have fairly simple shore power set-up. Unplug the two 120 AC outlets from the inverter and plug them into shore power. Since the inverter will be the biggest power draw I should be able to run the 12V DC side from the solar panel. Use the charger for when I get home.
