Here's some work I got done before Winter hit.
First layer.
I'm using 4x6 Rubber mats for a sound deadening layer.
Special order from Lowe's. $45 each.
Lay it out on plywood for easier cutting.
Tape together old newspapers to be same size as mat.
Create a template.
Cut the first mat to size and lay in van. Move on to the second mat with a new template. One small problem with the newspaper template. The newspapers are from 1979. I kept stopping to read them.
Next do the front mat. I wussed out on trying to do all the complicated cuts needed for the front wheel wells. I'll go back and do them as smaller pieces. This way only have to cut around the dog house. Didn't bother with template. Just measured and cut a rectangle (56" x 31", I think) then laid it down and trimmed.
Fourth mat goes between the back two and the front one. 6' x 28" wide. The gap between the mats is not perfectly parallel so a little trim to fit is needed.
Use double sided carpet tape to finish the rear wheel wells.
From remnants cut (2) 42"x10.5" pieces. One for each side to be wrapped over the top.
Almost all done with this layer.
