Painting the van. Back before it got cold:
The only equipment I had to buy was a paint sprayer and air valve at Lowe's. The small compressor I borrowed and I already had a good respirator and set of goggles. That was it for equipment.
The paint and clearcoat I got from NAPA:
Intermix MS Quart 56A Oxford White - $32.69
Reducer MS Quart CR232 - $13.49
Overall Clearcoat MS Quart FC720 - $23.49
Medium hardener MS 8-0z FH612 - $10.99
I used (2) of each.
Most of the rattle cans are sandable primer, 13 of them from Advanced Auto - $5.95 ea.
The acetone is for clean up and next time I'll buy it by the gallon.
Some 400 and 1200 grit wet/dry sandpaper and a boatload of newspapers and wide masking tape.
I bought this van used and the inside was pretty scratched up so I ended up painting most of the interior. Once I got that and the rust taken care of I was running out of good weather. On the exterior I just did the drip edge and the bottom section that has the chip guard.
As you can see from the one picture I'm working into the night to get it done while the weather holds.
Lessons Learned: If you're painting outside, don't work into the night. You be picking the bugs out later. Another tip, A single edged razor blade is really good at getting overspray off your windshield.
If you're careful the results are surprising good. Not just my own opinion. When working on the street other people will be sure to give you their observations.
Lessons Learned: When working on the street with respirator and goggles expect plenty of strange looks from those passing by.
The paint sprayer I use is the "Kobalt Small Gravity Feed Spray Gun - $37.96" from Lowe's.
This type holds the paint in a small container on top of the gun. The main advantage is since it's a gravity feed there is less parts to clean vs the type where the paint is held underneath the gun. Disadvantage is that it doesn't hold a lot of paint but if you run out it's easy to refill.
I also bought a "Air Adjusting Valve - $14.96" that attaches between the gun and the air hose so you can adjust the pressure right at the gun (important).
I had the advantage of practicing on the inside parts of the van which will be covered over when the conversion is complete. It doesn't take that long to get the hang of the painting. Learning how to properly adjust the gun I found to be harder. A big piece of cardboard is handy/nessasary for dialing in the gun.
