First today's Ford van weather report:
Yep, still cold.
Because of the weather I'm not able to do as much on the van as I'd like so instead I've been looking ahead. The first piece of furniture I'm planning on making will be the sofa-bed. There are several design considerations with such limited space so I'll need some dimension information.
Here are some diagrams I've drawn up. The measurements are not extremely accurate. They are for general planning purposes not actual cutting of materials. None are to scale.
The floor measurements are of the wood layer I've installed, not the metal base layer.
The sofa-bed will sit behind the drivers seat so I'll need to know how close I can get to it.
Another consideration is height. Part of the Penthouse Top installation was the addition of a Metal Edge that runs along the top edge of the van wall. This edge sits lower than the original ceiling. Need info on it's height and placement. In this photo you can see the Metal Edge along with what I call the Box which is a structural component of the Penthouse top. All these measurements are with the top down. The Bucket is also of note.
Window behind drivers seat.
The sofa-bed will sit in front of this window so it's height is important.
Cross section look at the wall.
The heights to the ceiling farther away from the wall. 16 1/2" measurements is at the floor.
Now for a self portrait.
I want the sofa seat to be as high as possible, for storage underneath, without hitting my head on the Metal Edge. I did "test sits" with different sized boxes and such and found that the Tidy Cat Bucket I'd been using as a work stool seems to be just about right.
So I'll plan on the sofa seat having the same height of around 14 1/2 inches from the floor. I'm 6' and that's what feels right for me. You should do your own "test sits" to see what you find to be comfortable.
