WVvan wrote:
Sofa-Bed.
It's not done yet but at this point I've finally got it all figured out.
Time to start the write-up. The sofa-bed will be the most complex thing I'm going to build for the van conversion. It would have been nice to put this off until later in the project but so many other elements depend on the size and placement of the sofa-bed so it has to go first.
The usual warnings apply. I've never designed and built anything like this before. I've had to make a bunch of assumptions (wild a** guesses) and not sure how these will work out in practice. Will find out after I put it to some use.
One more point. Even though this will fold out to a bed I don't believe it's sturdy enough for any serious "bouncy-bouncy". Seeing is how I camp alone that wasn't a design consideration, unfortunately. I like how the English would phrase it, "More's the pity".
When the the sofa-bed is in the bed position it will be 74 inches long by 42 inches wide. I choose 74" long since I'm 6 ft tall (72") so that gives me room to lay flat with a couple inches extra. 42" wide because when it's in the sofa position the seat and the back will each be 21 inches wide and that felt to me like a comfortable seat size. I'm using two electric actuators to open and close the sofa-bed.
For padding I've bought 3 inch thick foam and a 2" thick memory foam topper. Not yet decided about how to cover them.
Here is the basic design I started with. I've stayed fairly close to it.
So far on this build I've made more mistakes and wrong turn than I care to admit. Here's a picture of the sofa-bed bone pile and I'm not even done yet.
I got started on this about a month and a half ago. First cut the two end pieces. They are 30" x 31". I'm using 19/32" plywood.
Made the seat and back frames from a 3/4" thick pine planks I had laying around.
Each frame is made from five pieces. Here are the dimensions of the pieces used on the back frame.
The seat frame is slightly different in size. I had some 5-1/2" wide boards on hand so instead of ripping them down to 5" I just increased the width of the frame an inch. So the back frame is 74"x20" while the seat frame is 74"x21". 20" + 21" doesn't equal 42" but the foam is cut to 42" and it can easily overhang the edge of the frame by 1".
continued.
I've been following your wonderfully illustrated thread with great interest. I also have a "bone pile" in my basement. It's great to watch the thought process as you redesign. I spent many hours sitting inside my van with mockups clamped together and suspended from ceiling straps while I said "oh!" when folding things didn't work right.
Undoubtedly too late but I'll make a few observations from my experiences. I'm 76" tall and made our bed 80" long. It's pretty key that the foot of the bed on my side overhangs free space. I find that essentially I need my extended height on tippytoe to not kick the covers off. Methinks that 74" is a little tight for a 6'r. A top duvet that Velcro's to the memory foam bottom helps a lot.
Our bed width is 30" as a daybed/single or 45" as a narrow double. Both of these widths are supplemented by a couple of inches gap on the wall side. Not only does the bed effectively feel that much wider, it is really useful being able to tuck the covers down into the gap space.
So the question is: why did you settle on 42"? (We'll skip the jokes about meeting a female camper with the nickname "Slim".)
I am currently designing a chair that folds flat. The seat and back are 20" deep and are similar to your 21" versions. My DW is 5'3" and the 20" is slightly deep for her. I am also using 3" foam and believe this buffers the knee-bend problem. A problem I'm dealing with is that if the seat/back hinge point is at the plywood base, the cushions must either move or crush. I considered a more complex pivot that is centered at the top of the 3" cushions. That implies that the seat and back support panels only come together in the flat position. My inclination is to keep my simple piano hinge and let the cushions "float" with a topside fabric "hinge" like your drawing implies. I'll be curious to see if your actuator results in correctly positioned cushions. So far my reclining chair is manually operated but I may get inspired by yours!
