Sofa-bed continued:
I've tried to come up with a way to explain how everything works together. Hopefully this all makes sense.
The sofa-bed is in the sofa position. The switch is in the off position. Both limit switches have wires running to the NC (Normally Closed) terminal on one side and the COM terminal in the other side. There is only a complete current path through the switch if it is in the Open position. The two diodes directions are opposite of each other. Both the Drive Actuator and the Lift Actuator are in the fully extended position.
Flipping the switch down begins the conversion to the bed position. Power goes to the Drive Actuator which begins to retract. This causes the Seat Platform to starts to move forward and the Back Platform to slide down the Back Support. With limit switch #1 closed and the diode stopping current flow the Lift Actuator doesn't move.
In the diagrams I'm using red to represent positive and black to represent negative with current flowing from red to black and blue shows no current flow. It's not really accurate but I think it works well enough for this explanation.
Once the Drive Actuator has retracted enough it allows limit switch #1 to open. I've placed the switch so it opens only after the Back Platform has cleared the Back Support. With the switch open the Lift Actuator starts retracting.
As the Lift Actuator retracts it lowers the Back Platform. This in turn causes limit switch #2 to close. This shows the purpose of the diodes. With the closed limit switch the Drive Actuator would stop moving except now the diode gives the electric current an alternate path around the switch so the actuator can continue to retract.
Both the actuators are fully retracted and the sofa-bed is now in the bed configuration. I show the power switch in the off position but that's not really needed. The actuators will shut themselves off after either fully retracting or fully extending.
The power switch is now flipped up to convert the bed to a sofa. Only the Lift Actuator is energized at this time. Notice the diode with limit switch #2. When the Drive Actuator was retracting this diode allowed power to bypass the limit switch. But now that the current is flowing the opposite direction this same diode prevents the Drive Actuator from extending. The practical purpose for this is that I don't want the Seat Platform to start to move until the Back Platform has risen enough to clear the Back Support.
The Lift Actuator has raised the Back Platform far enough for limit switch #2 to open. This applies power to the Drive Actuator so both are now extending.
As the Drive Actuator extends it will cause limit switch #1 to close. This is the same situation from two drawings back. Even with the limit switch closed I still want the Lift Actuator to keep extending. So this shows the second diode doing it's stuff.
Both actuators keep extending until the sofa-bed is back in the sofa configuration then they shutdown on their own.
That's it. If it needs further explaining just let me know.
continued -
