Two weekends ago.
Advantage of a "B" sized RV. Just keep moving it around till you hit a level spot.
Previously I'd installed a trailer hitch so I can haul my bike with me. Now for the bike rack.
I use a fold-down style bike rack with my other camping vehicle, Subaru Forester with the WVBIKE plates.
The fold-down rack wouldn't work so well on the van. I could open the doors with a bike on the folded down rack but couldn't safely climb in and out of the back of the van. Because of that I went with a swing-away style rack.
I bought the Surco DBR300 OSI Swing Away Hitch Mount Bike Rack, 2" Receiver, Up To 3 Bike Capacity.
It was $226.58 on Amazon ( free shipping).
There are a couple of design problems with this bike rack but nothing that can't be fixed.
The bike is secured in this top horizontal holder. There are spaces for three bikes. Put your bike into the "V" groove then just tighten down with the two threaded knobs. The round knob on the right has a lock. Once you have the bike tightened into place you can "unlock" the knob so that it spins free and doesn't loosen the bolt underneath.
Even secured by these two bolts the bike can still swing so I always add a strap wrapped around the bottom brace to keep it in place.
Here is how the swing-out part of the rack works.
There is a large bolt that holds the two halves of the rack together.
Loosen this bolt.
Then pull on the cable release.
That raises this spring pin which allows the front half of the rack to swing away.
The two halves pivot on this bolt.
As you swing the bike you'll quickly see that it can only go so far before the back tire meets the van.
Where the horizontal bike hold-down is attached to the bike rack is another pivot point. Pressing down on these two knobs allow the top to rotate.
You can rotate the top 90 degrees.
With the top hold-down in this new position you swing the rack until the bike is parallel to the side of the van.
That allows full access to the back of the van.
Now to the design problems with this particular bike rack. There are two. I don't like the locking knob as a security feature. It doesn't feel robust but compared to the second problem it's small potatoes.
Here's the main problem. The pivot bolt that secures the halves of the bike rack together.
All it would take is a thief and a wrench to remove this bolt then walk away with the front half of the bike rack with the bike still attached. Nothing to stop them.
Here's how I fixed it. Had a friend weld on two pieces of steel angle. One onto each half of the bike rack then drill a hole through both pieces.
Putting a lock through the holes secures both halves of the bike rack together so even if the bolt was removed the rack will stay together.
Adding a steel cable to the lock means I can run the cable through the bike which secures the bike to the rack without worrying about the quality of the locking knob.
There was one other modification that had made to this bike rack. I have a step bumper on the van which is wider than standard rear bumper. To compensate for this extra width the square tube part of the bike rack that slides into the trailer hitch had to be extended by 1-1/2". The local machine shop did it for $20. Good price.
To secure the bike rack to the trailer hitch I'm using
Draw-Tite J-Pin Anti-Rattle Lockset for 2 inch Receivers. Currently around $26.
This J-pin is designed for 2" Receiver Style Hitches with 5/8" Pin Hole & 1/2" Pilot Hole.
The short leg of the "J" shape goes through the "Pin" hole and compresses the rack tube against the side of the receiver tube.
Once you tighten this nut enough (with included wrench) there will be no movement or rattle between the rack and the trailer hitch. It's like they are one unit.
When it's all tightened down, put the lock on.
I first read about this J-Pin lock on-line then went to a couple local RV/trailer dealers to buy it. Neither stocked it or claimed to know what I was talking about. That's odd. This thing really does the trick.
Some of these previous pictures are from this past weekend. After I took the bike off the van I headed for the
West Fork Trail.
Work on the van or enjoy using the van? Tough call.
