Webasto heater install continued:
Route the fuel line to the pump and trim off excess.
After having seen how small the fuel inlet was on the Webasto I decided to add a fuel filter.
Add the filter to the pump inlet side. The short pieces of hose and clamps came with the fuel line kit.
Insert the fuel hose into the the other end of the fuel filter.
Take some of the leftover fuel line and use it to connect the outlet side of the pump to the heater inlet.
Here's how the pump looked with all lines attached.
Had to get the supervisor's approval before proceeding. By aligning his sight with the bottom edge of the van he used that as a guide to decide if the pump was installed level or not.
It passed.
continued -
