Webasto heater install continued:
Before making a metal shield for the fuel pump I used my old friend posterboard to do a mock up.
I'll make the shield from this rusty piece of sheet metal I found laying around the garage. Except for the bottom edge it's a light surface rust. A quick measurement shows it to be 22 gauge.
You can see in the above photo that the sheet is laying on a metal table. I've not mentioned it before but the table is one of the things I recently inherited from Dad. Found that it's a necessity if you're taking up welding. Need to make an addition to the table for this project. Welded a 1" angle along the front edge of the table.
Used a grinder to remove evidence of my beginners quality weld and level out the joint surface.
The sheet metal wasn't large enough to make the shield without first some cutting and joining. Use a framing square as a cutting guide for the saber saw. Use the newly installed angle as a clamp point.
Need to put a bend in the sheet metal. Don't have access to a
press brake so I'll have to make something up. I've not done this before but I thought this might work.
Sandwich the sheet metal between the angle I've added to the table and another on top. Clamp securely.
Use a rubber mallet to bang on the edge of the sheet metal and bend it down. Didn't try it to bend it all at once. Just kept tapping away trying to keep the bend even.
End on view. Not too bad.
The edge was a little wavy so some extra work was needed using the table angle like a anvil.
Put another bend in the other end.
Place the clamps so the metal will clear them as it bends.
Both bends done.
Test fit. Looks good.
continued -
