Kitchen Cabinet, Post #10
Cut and drill a new set of hinge pads.
I probably did myself a favor by messing up the first set of pads. The plan was to drill each by hand but it's so much easier to do on the drill press.
This time around I custom fit and weld each pad in place. One door at a time.
Install #10-32 T-nuts into the doors.
Check that the water cans will fit through the access door as expected.
Take everything apart and paint the frame.
Stain all the plywood doors, cover panels and the countertop. All sides.
continued -
