Kitchen Cabinet, Post #15
Need to install the on-off rocker switch for the water pump. Mark out a location on the the front cover panel of the kitchen cabinet.
The switch requires a square hole. So start with two round holes.
Use a jigsaw to join the two holes then a file to clean up the hole.
Good fit.
Since I'm in a switch installing mood, mount the controller for the Webasto heater.
Prepare the countertop and and it's laminate sheet.
Bought another Formica sheet. Used it to laminate the front side of the three doors.
After the laminate sets up it's time for the edge router.
I'd forgotten how much of a mess routing the edge was
In the middle of this job my cheapo edge bit fell apart. A quick trip to Lowe's and $17.95 later I had the new edge bit, on the left.
After routing use a file to fine tune the edge.
Here's the cut-out for the drop leaf drawer hardware. I'm laminating the front side of this cover panel.
Here's how it looks after edging. I needed the can of "OOPS!" to completely remove the Formica label.
Looking good but still not done.
continued -
