Solar Panels continued -
Up to now the work on the solar panels has been done with the penthouse roof down. Need to raise it to continue working on the wiring. Don't want to take a chance of the panels falling off so I'll put bolts through the bracket holes and the roof to stop the panels from shifting. Add the rubber pad for each bracket before inserting the bolt. I wonder which pad goes here?
There's no nuts on the bolts yet but this should be secure enough for raising and lowering the top.
Wasn't done yet but decide to step back and and admire my work.
Something I noticed during the walk around. If I place a level on the front panel.
The rear of the back panel is this far below that level.
I hadn't expect that much of a difference between them but luckily the rubber pads between the brackets and panels have given the mountings enough flexibility so there's no problems.
So raise the roof with the solar panels for the first time. Here's the amount of force needed to raise the roof now. Subtracting 10 lbs for the weight of the electric jack I'm using gives 153 lbs. I'll be covering this aspect in a upcoming posting with more details.
Here's the free ends of the parallel cables for the solar panels. While working on the wiring with the roof down I was just feeding the cables through the holes in the nylon half rod and they were sliding into the gap between the penthouse roof and the top of the van without any binding.
Now switch to the inside of van. This is the right rear corner (passenger side) of the penthouse top. Here is the conduit that protects the wires that run to the brake light on the outside of the top and the inside light on the ceiling near the front. These wires were run by Sportsmobile when they installed the top.
To run the wire for the solar panel I'll have to do something similar so let's see how they did it. There is a finish piece that runs across the back of the van below the top.
There's just a couple screws with caps that hold it in place.
Pulling back the cloth in the corner shows the hole that's drilled through the roof of the van in which the wires are run. That's how I'll get the solar cables from inside the penthouse top to the inside of the van
So how to get run the cables from outside the penthouse top to the inside? They explained it to me when I bought the top. This is the left rear corner (drivers side) of the top. I'm going to start removing these screws until I can open up a gap in where the canvas side meets the roof.
Before proceeding, unclip the top most bungee cord on the outside rear of the penthouse top. Found it's easier this way.
Start with the roll up shade.
Keep removing screws till the canvas comes free. That's what I'm looking for.
The brake lights wires are of a smaller gauge than the solar cables so were more flexible. SMB was able to just snake them through the gap. For the cables I'm going to instead drill a hole on this white covering panel.
Then feed the cables through.
This is the view under the top. The cables come through the roof, make a half loop to avoid the bolt hole then fit in between the canvas and the top. Since the half rod brings the cables in at such an acute angle it's a nice tight fit against the underside of the roof as opposed to if they came in at 90 degrees. I'm trying to avoid the bolt hole enough so the cables won't interfere with the nut and washers that will go there.
Didn't know exactly how the wiring was going to end up being routed through the top until I got to this point so put off this next step until then. Pulled about two inches of each of the two cables back through the half rod so the slack was under the solar panel. Can' t really tell from this out of focus picture but next I put a big gob of silicone II on the wires and coated those couple inches of slack generously. Then drew those gob-smacked cables back through the half rod. Smeared the remain silicone over where the cables enter the half rod. Hopefully this will waterproof the half rod.
continued
