LED Lighting
This is another of the projects I started working on because the trim and headliner were removed. This will be for LED Lighting in the house section of the van. While Disco Lights were just for fun these lights will be more practical. The LEDs are on a flexible strip and will be encased in a square acrylic tube just like the Disco Lights. These LEDs are rated as "cool white".
Unlike the Disco Lights I want the switch to be part of the light fixture. Here's what I have to work with. A simple on/off switch, 1/2" square acrylic tube, 1/2" U shaped acrylic channel and acrylic sheet.
Will be making two fixtures so create both switch enclosures at the same time. Use the clamp to hold it all together then apply acrylic cement which is drawn into the space where the acrylic pieces touch. The switches aren't affected by the cement. They are just there as spacers.
Cut the switch enclosure in half. Cement one to the end of a section of square acrylic tube. Use a string to feed the flexible LED strip through the tube.
Wire the LED strip to the switch and add a plug.
Now to power it. Create a wiring harness. The positive power comes from the house battery fuse panel.
Get the ground from a bolt on the B pillar just below the roof.
Tape the wiring harness to the roof of the cab. Two of the connectors are for the LED lighting while the third is what powers the Das Boot light from the previous posting.
Wait till it gets dark and give it a try.
Here I'm just holding the light in place. Looks OK.
How to mount the fixtures? Running along both sides of the penthouse opening is a cloth covered metal reinforcement. Will use these 1/4" square rare earth magnets. They are strong enough to stick to the metal even with the cloth in between.
Here's an idea of how strong the magnets are.
Again use 3M VHB to attach the magnets to the square tube.
Here's the light over the kitchen held in place by the magnets. It's quite solid.
The second fixture will go over the sofa-bed. After fitting the LED strip into the square tube it needs to be trimmed. This marks one of the cut points.
The round pads are were the wires are soldered.
The first section of flexible strip used over the kitchen had wires already attached. This was cut from that strip so need to solder on the wires.
The square tube came in 6 foot lengths. The second fixture is longer than that so added a second section of square tube to the end.
The strip isn't the exact length of the square tube since it can only be cut at certain locations. Any left over I just bent over and slid back into the tube.
Sofa-bed lights.
LED lighting after dark.
Since I'm making this up as I go never sure what it will look like on the other end but really happy how the lights turned out. The pictures don't do them justice. Found in using them that the decision to incorporate the switch into the square tube was right. When standing with the top up the switches are out of sight below the penthouse edge. Just have to run my finger along the square tube and I'm sure to hit the switch.
That's the end of the LED Lighting project. By the way, it's getting kind of lonely in this thread. Anyone find this stuff useful?
