This thread has been kind of quiet lately. Between my new (to me) lathe:
and camping:
Green Ridge State Forest, Maryland
and biking:
C&O Canal National Historic ParkPaw Paw Tunnel
Lock #58
I've not been posting much. Still working on the van. Just not posting about it.
Next up project is what I'll call the "fridge cabinet". This will be on the drivers side, next to the sofa. It will hold the Engel fridge, porta-potty, and a couple drawers.
Fridge Cabinet - Post #1
Had trouble getting accurate measurements from the section of the van where I wanted the cabinet to go since the van isn't level and the wall curves in towards both the top and the back at that point. Making a wooden mock-up was the best way to go.
With the curved wall I want to find what is the optimum location. If the fridge is mounted at a lower level the cabinet can be moved closer to the wall which gives more room to the center aisle.
I can gain some space by removing the wall panel while deciding.
A quick note about the wall panels. Here is a side view of the panel just removed. This panel started out as flat when first installed but has now taken on a curve that matches the wall. I'm real happy how the "foam insulation+fiberboard+headliner material" wall panels have turned out.
continued -
