Fridge Cabinet - Post #6
When taking measurements before ordering the drawer sliders I didn't think the frame could be moved as close to the wall as it ended up and still fit the fridge. This increases the aisle width but messes with one pair of sliders. Nothing that can't be fixed with a slight intrusion into one wall panel.
The thickness of the wall panel was all the extra space I needed. Sealed off the opening in the back.
Drill holes in the right side covering panel for the TV mount.
Bolt on the TV mount.
The TV slips onto the mount from above.
Mount the left cover panel on the frame. I'm using extra clamps since the plywood backing had developed a slight warp.
Using sheet metal screws to attach the cover panel to the frame.
Here's the frame with both panels installed. You'll notice the red and black wire with the white plug hanging in the back. This will be the power to the fridge. I ran the wire when the wall panel was off.
Mount the top cover panel.
Remove the panels and paint the exposed parts of the plywood. Both for protection and for looks.
Everyone's a critic.
Painted and back together.
Now here's something I'm not happy about. Couldn't find any corner molding that I liked so ended up using this 1/2" aluminum angle.
I'd be happy with 1/2" white vinyl angle molding but can't find any locally which pretty much means Lowe's. If you're reading this and have a suggestion please let me know.
Bolt the frame into place.
Here is one of the main reason I installed the tie-down rings. My walking stick. Before it was always in the way. Now there's a place to safely stow it without me tripping over it.
Right about this time in the build I suffered the lose of one of my favorite tools. This one.
It's a Canon Powershot. Up to now every single picture and video you've seen in this build thread, including the camping ones, had been taken with this camera. I really like this camera because over the years I beat the living spit out of it and it just kept on working. It's been dropped multiple times, beaten against rocks while hiking, tossed around then dropped some more. The display on the back has a couple cracks but still works. Remember the TV ad with the ape and the suitcase. Something like that.
Well it finally met it's match in the penthouse top. I accidentally closed the top on it while working on the fridge framework. It split open like a clam and when snapped back together it stopped working. That's not so say it can't possibly be fixed. Just figured it's time to get another camera. This particular model isn't made anymore but thanks to the wonders of ebay I bought an identical Powershot that's barely used. I'll have to remember to keep the new one away from the penthouse top.
