dougrainer
Jul 12, 2014Nomad
When a customer come to me with your problem, I take the motor linkage LOOSE. I then spray liberal amounts of liquid wrench on all linkage and pivot points. I have to then with great force manually force the steps to retract and extend. It is usually very difficult to do until the Liquid wrench penetrates the pivot points. Once you have this done, the steps will then easily just fall open and with one finger you can retract. Then reconnect the linkage. THEN, clean and lube once a month. Your complaint is what usually ruins the step motor. Doug
38,778 PostsLatest Activity: Jun 10, 2026
