SUPERCHARGE's avatar
SUPERCHARGE
Stick with truck camper or go for RV?
Hey guys. kinda new to all camping RV's, tt's and tc's. I need to ask the more experienced: are there 20-25 ft class A or C RV's which are a bit more off roadable? As in able to travel the beaches, muddy and rocky trails in a similar ability as a standard 4x4 pickup? Most seem way too low and have too much tail end after the er wheel. A few months ago, I got a truck camper at a steal of a price. It served me more than I could of imagined. After a few uses, I realized that i'll most likely start using a/my camper more than originally anticipated and could use the more advanced features an RV can offer over a TC
Here's my situation... i'm single, will be traveling long distances for my job, often off the road and during three seasons. will not be using campgrounds for long periods. Usually be in lesser public and more remote/rougher areas for short periods.
Here's what I like about my current setup: mileage is at about 17mpg and confident i could do better. With a tuned 5.3 liter engine, extended cab, have tons of power. High off the ground and driving is stable due to helper springs, easy to manœuvre and semi-comfy on the highway. I can also park and sleep a night anywhere in park parkings/parking lots, cities without being bothered with this smaller setup.
What i'm not liking at all is the camper's stability in the bed. Despite being anchored tightly to the bed rails by four brackets, i find there is way too much movement and flex between the TC and bed when the road gets remotely rough. I could also use a bit more room. And i don't have the luxury of a proper shower, generator or extra battery (which kills the ability for Air conditioning or entertainment except the VERY rare times i'll be plugged in.) And an RV clearly seems like a comfier ride with it's larger more stable axles.
So i'd either like a larger TC that has more of the abilities of an RV and find a way of keeping it stable or find an RV that isn't afraid of getting rough like truck. Do these exist Or am I dreaming?
  • Remember. Your truck camper is also an RV / recreational vehicle. Actually ALL campers are RVs. Motorhomes are just a different kind of RV.
  • Ok thanks a bunch for the info guys. Funny about the earth roamers.I looked at them quite a bit but obviously a bit over budget, a bit narrow and not so great a fuel.
    I could of swallowed the cost of fuel for an RV if I was absolutely happy with everything else. Bit yeah, under 10mpg... pretty nasty for a one person on long travels. As for trailers... no go. Have already been in really tight trails and spots in which I would of never come out with a trailer...reversing and turning around on tight lake-end dirt roads and beaches.
    So i'll go with your suggestions in that case and stay with the TC's. Ill talk to some tc guys about trying to set myself up a bit better.
  • Check out Tiger Motorhomes......you can pick them up at a more reasonable price than Earthroamer and they are true off road RV's....Also Earthroamer has a used program ....200,000 dollar range.
  • They exist alright and can be yours for around $400,000.00!
    http://earthroamer.com/
    With that being said almost anything you touch is not going to get 17mpg like your stated current MPG - which is absolutely amazing! Especially considering the weight of the TC and higher less aerodynamic profile of the rig going down the road. I would say be prepared to get 6-10MPG if buy an RV. That might be reason enough to just keep what ya got.
    You probably need to decide which is more important to you though - the extra capability a TC offers with 4x4 and ease of driving/parking OR the extra amenities a larger RV offers.
    If you're comfortable towing - you could have the best of both worlds really. 4x4 truck and a 20-25ft camper or so. Mine is 30ft long and has a higher than average ground clearance for a trailer. I've gotten into some pretty knarly forest service camping spots (not manicured campgrounds) and have needed the 4x4 on a few occasions. I almost exclusively boondocks with no hookups. You might consider this type of setup. Your MPG wills till suck. I get around 13mpg towing overall. Best was 14 or so and worst around 10.
    Best of luck to you whatever you decide.
  • I would stick with the T/C if your going to be using remote roads, sandy beaches and muddy, rocky trails. If you can afford to upgrade I would go that way, but still stay with a T/C and a 4x4 truck. JMHO
