ricelake922
9 years agoExplorer
Still broken
Hello. I have a 1996 Monaco Dynasty. In previous post I wrote that I had seen three states to Florida by tow truck. The same problem occurs which is the 4D batteries lose power after 2 days. I can ...
rgatijnet1 wrote:
Monaco coaches of that era had manual mirror heat switches, meaning they did not automatically turn off. Have you checked to see if the mirror switch is on.
As mentioned, has anyone put an ammeter on your coach, with everything turned off, to see what the draw is on your batteries. It will not be zero because of your CO and LP detectors, as well as you radio memory, but it should be less than 1/2 amp.
