WyoTraveler
May 31, 2016Explorer
Wheel base Vs length should be about 53% or more. If you look at the back of the Bounder the bottom slopes upward. All that said, A MH of any type is less likely to be driven off road. We drive off road just to get to a camp sight. A MH is just too heavy to risk off road driving. On the highways you'll never have a problem. What year is 30 yr anniversary? The shorter the wheel base the easier it is to maneuver in tight areas and the more the back end swings in the opposite direction in a turn. The longer the wheel base the better it will handle on the highway. The shorter the wheel base Vs length the more you will spend on anti away. I do not have a Bounder but it would have been my choice except I found a great deal on another MH I couldn't pass up. If I recall the Bounder has a W/D option.
38,776 PostsLatest Activity: May 15, 2026
