- 6MISFITZExplorer
BUTCHPHI wrote:
You got my vote for best response ... but it sounds like you are still on the fence about using it on your own tires?
You could shoot a 45 cal. bullet through your nitrogen filled tire and because those sucker nitrogen molecules are so large you probably would lose any air.:B
Mike. - BUTCHPHIExplorerYou could shoot a 45 cal. bullet through your nitrogen filled tire and because those sucker nitrogen molecules are so large you probably wouldn't lose any air.:B
- CapriRacerExplorer IIThe reason NASCAR uses nitrogen in bottles is air compressors generate sparks (both electrical and motor driven generators) You just don't want sparks around areas where there might be fuel spills!
- Mr_Mark1ExplorerNow that I think about it, the Prevost service center put nitrogen in my tires and they do seem to stay at a rather constant pressure (not much loss).
MM. - jfkmkExplorer
usersmanual wrote:
jfkmk wrote:
usersmanual wrote:
Nice factoid. I think it is just easier to roll in for the week with a few nitrogen bottles vs the logistics of a compressor.
I assume NASCAR uses nitrogen in pit row also. Otherwise the pit crew could never change tires that fast using plain air in the jacks and gun.
wrong ::nitrogen has no bearing on the speed of the air guns ability to be fast or slow and the jacks used are all hydraulic
However compressed Nitrogen gas is safe unlike compressed oxygen
when it comes to sparks and or open flame etc
Who on earth would use compressed oxygen for an air gun?:h
compressed air then if you are not sure what we are talking about here;; is not the air you breath called oxygen and is it not used a via air compressor to run air guns ;; last time I looked it was
surely your not that dumb are you
There is a HUGE difference between compressed air and compressed oxygen. Not so much a concern with sparks and open flame with compressed air as with compressed oxygen. - DrewEExplorer II
The air we breathe is about 4/5 nitrogen and 1/5 oxygen, with a small amount of other gasses (e.g. argon and carbon dioxide) and some rather variable amount of water vapor. I've only heard it called "compressed air" when used for air tools, not "compressed oxygen."
Compressed (pure) oxygen is of course used for some things other than powering air tools, such as oxyacetylene welding, medical needs, and (when liquified) as a rocket engine reagent. - JaxDadExplorer III
Ivylog wrote:
In 12 years I have never gotten any water out of the two air tanks on my DP .........
Seriously? I'd like to know where you drive. - jfkmkExplorer
Who on earth would use compressed oxygen for an air gun?:h - The wink at the end was to imply sarcasm.
- usersmanualExplorer
38,763 PostsLatest Activity: Jul 22, 2018
