RacerX10's avatar
RacerX10
Stink from new(ish) RV
2013 Fleetwood Jamboree 25k
75,000 miles
After a 600 mile drive to our destination, then letting the RV sit unoccupied for 2 days, when we got in to drive back home and noticed a VERY strong rotten egg smell.
Vehicle was sitting on a slight incline, low in the rear, while parked for 2 days.
Everything seems to be working fine in the coach. The smell dissipated after 30 mins or so going down the road.
Only things I know that can make that smell are catalytic converter and RV fridge ammonia, but I can't believe on a 2 year old RV we'd be having problems with either.
Anybody have ideas ?
Thanks !
  • Odors in RV
    Battery boiling due to being overcharged/low water level....happens when on AC power source and not so smart converter/charger OR bad battery cell
    Fridge......ammonia leak. BUT fridge stops cooling when that happens
    Sewer/septic/waste holding smells........toilet bowl not holding water
    Air Admittance Valve(s) not sealing (installed on sink drain lines after 'P' traps --- inside sink cabinets)
    Sulfur smell........hot water heater -----stagnant water/high iron-sulfur connect water, high bacteria in water, magnesium anode rod
  • Could also be hot water heater. Run the pump and smell the water. Check the bathroom next to see if it the toilet, then move on to other possibilities.
  • j-d's avatar
    j-d
    Explorer II
    Could it have been "sewer gas?" It can happen easily if you were on a full hookup site and left a drain valve open, even partially.
  • 2oldma wrote:
    battery
    Interesting.
    I forgot to mention that I did leave the fridge running in "gas" mode for those 2 days, so it was on battery / propane power for the whole time while parked.
38,766 PostsLatest Activity: Jan 10, 2026
