kg1d_dxExplorerSep 19, 2015Stinky waterI keep getting that surfer smell when I turn on the hot water. I have had this problem in the past, but a cup of bleach in the tank takes care of the problem. Now I get the smell every time I use the ...Show More
Old-BiscuitExplorer IIISep 19, 2015IF you have an Atwood WH (no anode rod) you still need to drain/flush WH.Sulfur smell/hot water....that comes from the water heater. Sulfur smell/hot & cold water....that comes from fresh water tank and/or water source
