From the sounds of it, the fault occurs when you are stepping on the go pedal a bit harder than is needed to cruise down the flatlands. Air filter and especially the fuel filter that are on the verge of clogging up would cause this very behavior. Both are a relatively cheap fix.
I don't happen to have that very rig, but I do have a couple diesel vehicles and they both have done that to me. The Jeep goes one step further when the fuel filter starts to clog up: it goes into limp mode which requires an engine restart to clear. And "limp mode" is very limp indeed.
