RVER
Jan 13, 2017Explorer
Does the door stay closed when you pull on it? If not it may be the tongues are stuck in too far OR that the tongues are ok but the bar they are supposed to get behind is pushed down a little from slamming. That happened to me and we pulled the bar up just a little so the tongue could stay behind the bar and now they lock. NOT sure this is what you were speaking about, I also had to clean and then lubricate with dry lube the tongues that in some cases were halfway down inside so they were not engaging the bar, you want them to spring in and out very nicely.
