BruceMc
Sep 29, 2018Explorer III
bobndot wrote:
Maybe next year I will weld up two 3" wide straps with 90 degree angles and attach them to the interior right and left edges , run them down the interior sides and across the bottom of the bins.
I will make a new plywood bottom to rest on the 3" bottom straps as a full bottom support. My goal is to keep weight off the plastic bin.
When I do it, I will post step by step pix. When I do this can I call it the 'BruceMc II project' ? :B
I like it!
I'll post a few images once I complete the passenger side compartment, probably today. The brackets needed a bit of modification as that compartment is a bit different.
