mlts22
Jan 23, 2014Explorer II
Handbasket wrote:
Bear in mind that weight may be the limit on some C's, especially ones with longer rear overhangs. There may be plenty of volume, but rear axle or total allowable weights may keep you from using all of it. Even some short RV's are weight-challenged.
Jim, "Mirror, mirror on the wall, what the flamin' heck happened?"
Especially true with Sprinter models. I'd check the CCC/OCCC, and usually it might be around 1000 pounds or so. Fords tend to be better, but even those, it is a good idea to check weights.
