- ernie1Explorer III figure if it happens one can simply loosen the flexible hydraulic line connection at the leveler to allow fluid to drain out as the ram portion is moved back up. Haven't had to do it yet but it should work. A little messy but not a big deal. Could do this in a couple of minutes.
- way2rollTrailblazerThe only issue I can see storing with jacks down, is that if there is an issue and they are stuck in the down position - you aren't going anywhere.
- sprint99Explorer
memtb wrote:
Needed or not, I always store our class c with the hydraulic leveling extended. While it my “not” be necessary, I feel better having the suspension “unloaded”! It also maintains our unit level, as our parking spot is not perfectly level! memtb
I do as well. Ours has spent the majority of its life up on the jacks. Never had an issue and have spoken directly to jack manufacturer whom said "That's why you have them, to use them." No long term issues if we just spray the extended cylinders with a dry lubricant, which we do.
As long as one uses their head when setting them, there's no worries for over flexing the frame or all the other crazy worries I see people post about. People just need to use common sense. - memtbExplorerNeeded or not, I always store our class c with the hydraulic leveling extended. While it my “not” be necessary, I feel better having the suspension “unloaded”! It also maintains our unit level, as our parking spot is not perfectly level! memtb
- MDKMDKExplorer
wildtoad wrote:
Depends on your definition of short time perhaps. Regardless I always put my levelers down when parked for at my home even for just a few days. May not be a lot of help but makes sense to me to take the load off the tires and suspension. For longer stays at home, I read In a Goodyear (I think) guide that the tire pressures should be increased by 25% but remember to set it back to normal when getting ready to go on the road. Some may do this, some may disagree with this, but that’s what the tire company said to do.
From the Goodyear RV tire guide...
storing your vehicle properly helps protect your tires.
• Keep your vehicle in a cool, dry storage area out of direct sunlight and UV rays.
• Unload your vehicle so that minimum weight is on the tires.
• Inflate your tires to recommended operation pressure plus 25%, but don’t exceed the rim manufacturer’s inflation capacity.
• Thoroughly clean your tires with soap and water before storing them to remove any oils that may have accumulated from the road.
• Move your vehicle at least every three months to help prevent cracking and flat-spotting, but avoid moving it during extremely cold weather.
• Place your vehicle on blocks to remove the weight from the tires. If the vehicle can’t be put on blocks, make sure the storage surface is firm, clean, well-drained and reasonably level
Agreed. Stored our Sunstar in the driveway with the leveling jacks down. Only issue might be keeping the rams and the rest lubricated and treated for corrosion. Don't have leveling jacks on the Navion. Yet. - wildtoadExplorer IIDepends on your definition of short time perhaps. Regardless I always put my levelers down when parked for at my home even for just a few days. May not be a lot of help but makes sense to me to take the load off the tires and suspension. For longer stays at home, I read In a Goodyear (I think) guide that the tire pressures should be increased by 25% but remember to set it back to normal when getting ready to go on the road. Some may do this, some may disagree with this, but that’s what the tire company said to do.
• Place your vehicle on blocks to remove the weight from the tires. If the vehicle can’t be put on blocks, make sure the storage surface is firm, clean, well-drained and reasonably level - MerrykaliaExplorer IIWe have the auto-level on our fifth wheel and we store it on a sloped parking area that is paved, but we also have electric available, so our fridge stays plugged in and running. We always hit the auto level since it takes about a minute and a half to do.
- LwiddisNomad IIIBe sure you know what you have...stabilizers or levelers. Levelers will stabilize but stabilizers are not built to level.
- ScottGNomadIMHO, tires really dont mind having normal weight on them.
