KCFDCapt
Aug 30, 2014Explorer
DiskDoctr wrote:KCFDCapt wrote:
I see your lines are copper. Did you specify copper pipes that are approved for propane? Propane will corrode pure copper and the pipes must be tinned inside to be used with propane. It may be some of the corrosion has come loose and is plugging the flow of gas.
I've never heard of this. Can you cite a source?
http://www.propanecouncil.org/uploadedFiles/REP_10014%20Interfering%20Factors%20Copper%20Strip%20Test.pdf
38,773 PostsLatest Activity: Apr 22, 2026
