wa8yxm
Apr 29, 2014Explorer III
rgatijnet1 wrote:
Go to a Radio Shack and get some of the electronic cleaner that displaces moisture. Then, when you have the problem you can spray it on one area at a time to isolate the problem. I am guessing that it is at one of the major electrical connectors.
Radio Shack.. That (Displacing water, or rather Water Displacement) is what the WD in WD-40 stands for.
Yup, that is what it was designed for.
The problem: Your Power gear system has 3 main modules not counting the jacks, One is the sensor pod, I Strongly suspect this has some control devices in it too.. You need to locate it,, Alas, I have no idea where to look.
38,707 PostsLatest Activity: Feb 28, 2025
