dougrainer
Mar 20, 2022Nomad
Go to either Headlamp and look at the wiring behind the frnt cap. FIND the heaviest White ground wire running to either head lamp. Run a 12 gauge WHITE wire from a good frame ground bolt and just splice this ground wire around that Headlamp ground. See if the problem goes away. If so, make this new ground wire and good splice. Doug
