wny_pat wrote:
wwest wrote:
Electric RV hot water heater is something I never knew existed, too many BTUs required.
Hott Rod Water Heater
. They are quite popular.
Both Atwood & Suburban have OEM combo electric/propane models
Electric element just like a home water heater...1400W
Those aftermarket drain plug heaters are only 325W
OP
Do you have AC power to other items in coach...microwave, fridge on electric etc.?
Are you 50A.....maybe lost one leg of power?
Have you check the power pedestal receptacle for 110V on both hot legs?
Have you checked 110V on both hot legs coming out of 'surge guard'?
Have you checked 110V on both legs at end of power cord/connection?
Have you checked in AC Dist panel for both legs being hot?
Tripped 110V AC circuit breakers don't always look tripped.
Open your AC Dist panel
Turn breakers OFF then back ON to reset
